mark
Enables the marking of the DSCP field
in the IP header. Use this command to set the IP DSCP bits for QoS using an ACL. The mark
action of the route maps takes precedence over the mark action of an ACL.The DSCP field
in an IP header enables packet classification. Packet filtering can be done based on
traffic class, determined from the IP DSCP field. One DSCP value can be configured per
route map entry.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
mark ip dscp <0-63>
Parameters
mark ip dscp <0-63>
ip dscp <0-63> |
Marks the DSCP field in the IP header
- <0-63> – Specify
a DSCP value from 0 - 63.
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#mark ip dscp 7
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context
route-map 1
default-next-hop wwan1
mark ip dscp 7
